1997 Deville oil light turn off engine now!! help
Old May 3, 2007 | 07:12 PM
Michaelrj9's Avatar
Default 1997 Deville oil light turn off engine now!! help
Hi all
I have a 1997 Deville the oil light would come on and says stop engine low oil pressure!. I can go for weeks without a problem but then that is what happens it can lastonce or twice or maybe for a few days. Also the car would die sometimes if you let off the gasalso.
I took the car into the dealership and they said it is the EGR valve does that sound like it could be causing the low oil pressure? I know the EGR could cause the dying but could it also cause the low oil pressure?
Thanks
Michael
Old May 6, 2007 | 11:17 PM
FLCaddytech's Avatar
Default RE: 1997 Deville oil light turn off engine now!! help
If the EGR is sticking it can cause a rough idle or stalling.
If the engine speed (RPM) gets too low the low oil light could come on.
I would bet that it's 2 seperate problems.
You could have the oil pressure tested when the light comes on , but that can be difficult to catch if it only happens every couple weeks. I would put an oil pressure switch in and go from there.
I usually don't recommmed just throwing a part on without proper diagnostics, but it's cheap enough and i have seen sveral fail just the wayyou describe.
Old Jun 3, 2007 | 09:24 PM
alix09's Avatar
<https://www.cadillacforum.com/m_8786/tm.htm> How to change your ERG valve... I am not taking any credit on this just trying to help out
Old Jun 3, 2007 | 09:52 PM
G.A.R.Y.'s Avatar
Helping out is great, no worries. Actually I believe you will find that post in our FREE faq section also. Nice lookin out!!
MATTYL88
Jan 31, 2013 07:41 PM
CaliCaddy
Mar 18, 2011 05:45 AM
cooleric2000
Aug 3, 2010 04:22 PM
davefr
Eldorado Biarritz
Nov 29, 2008 08:01 PM
colepops
Jul 6, 2008 02:57 PM
