1997 Deville oil light turn off engine now!! help
Hi all
I have a 1997 Deville the oil light would come on and says stop engine low oil pressure!. I can go for weeks without a problem but then that is what happens it can lastonce or twice or maybe for a few days. Also the car would die sometimes if you let off the gasalso. I took the car into the dealership and they said it is the EGR valve does that sound like it could be causing the low oil pressure? I know the EGR could cause the dying but could it also cause the low oil pressure? Thanks Michael |
RE: 1997 Deville oil light turn off engine now!! help
If the EGR is sticking it can cause a rough idle or stalling.
If the engine speed (RPM) gets too low the low oil light could come on. I would bet that it's 2 seperate problems. You could have the oil pressure tested when the light comes on , but that can be difficult to catch if it only happens every couple weeks. I would put an oil pressure switch in and go from there. I usually don't recommmed just throwing a part on without proper diagnostics, but it's cheap enough and i have seen sveral fail just the wayyou describe. |
<https://www.cadillacforum.com/m_8786/tm.htm> How to change your ERG valve... I am not taking any credit on this just trying to help out:eek:
Helping out is great, no worries. Actually I believe you will find that post in our FREE faq section also. Nice lookin out!!
