Help! when turn on car, heat is at full blast cant turn it off
Old Jul 4, 2008 | 01:29 PM
colepops's Avatar
Default Help! when turn on car, heat is at full blast cant turn it off
I have a 93 deville and when you start up the car, the heat is at full blast and there is no power to the heat controls to shut it off. The gas gauge also does not work now. All the fuses are good and so I dont know if its an electrical problem or something else. Help!
Old Jul 4, 2008 | 01:41 PM
Katzmans Caddy's Avatar
Default RE: Help! when turn on car, heat is at full blast cant turn it off
Pull the blower fuse for now, at least you can drive it without getting blasted. Hard to diagnois electrical problems on board.
Old Jul 4, 2008 | 01:51 PM
colepops's Avatar
Do you know where that is located? I can't find it
Old Jul 4, 2008 | 01:58 PM
Probably a maxi fuse underhood drivers side over wheel well. Check owners manual to be sure.
Old Jul 4, 2008 | 09:17 PM
colepops's Avatar
Thanks i found it. there is some kind of power going to both the heat control and gas gauge thing, but cant control either one of them. there is just a lowercase "d" displayed in each of the boxes. very strange.
Old Jul 6, 2008 | 02:08 PM
Lithorian's Avatar
could be a bad BCM i think it was
Old Jul 6, 2008 | 02:57 PM
colepops's Avatar
2many projects
May 22, 2014 08:00 PM
kidcudi
Jun 16, 2009 09:25 AM
hotleonard
Jul 18, 2008 06:20 PM
Michaelrj9
Jun 3, 2007 09:52 PM
