1989 deville oil change
Old May 7, 2007 | 07:56 PM
seedyeh's Avatar
Default 1989 deville oil change
Hi all, new to this forum, have a quick question because couldn't find it in the search.
We have 1989 cadillac deville and want to change the engine oil and the oil filter.
However, I can't seem to locate the drain plug , there's no indicator that says 'engine oil' or similar like in the other cars I've done.
There is 1 bolt directly parallel to the ground under the engine which I *think* is correc, but I just want to make sure.
Also, the oil filter is located closer to the top of the hood, do I have to remove anything prior to removing the air filter?
I do not want the oil to leak down onto the cables/engine
I can snap some pictures later tonight...
thanks again
and sorry for the newbie questions...
Old May 8, 2007 | 08:00 AM
seedyeh's Avatar
Default RE: 1989 deville oil change
hi, i found the drain plug, located parallel to the floor
the oil filter was a bit hard to get off, so i put a plastic bag around it while removing it to collect any excess oil
what an awkward design for the oil filter :\
hl8a
Big Block V8s
Sep 8, 2008 06:18 PM
SoulRebel
Nov 9, 2007 04:34 AM
420Deville
Sep 30, 2007 07:32 PM
