1988 DeVille and ABS
Old Dec 31, 2006 | 01:48 PM
theatreman's Avatar
Default 1988 DeVille and ABS
How can I tell if my 88 DeVille has ABS (antilock brakes)? I know there should be a light in the information center, but there is the possibility that the bulb is burned out. Any other easy way to tell other than taking a spin in a rain-soaked parking lot? Thanks!
Happy New Year
Old Dec 31, 2006 | 04:29 PM
brougham1's Avatar
Default RE: 1988 DeVille and ABS
Hey T-Man: When you are braking fairly hard with the ABS system you should feel a pulse on the brake pedal. You may even feel the pedal come back up a bit as the system eases the pedal back a bit. You can also look under the front of the car and see a toothed ring and a round sensor unit mounted on the ring, which will be just inboard of the brake assembly. You should notice an electrical type cable running to the sensor. Happy driving.
norfmo
Eldorado Biarritz
Dec 2, 2010 08:49 AM
99STSGUY
Aluminum Block V8s
Jul 7, 2010 06:52 PM
The Allante Pub
Mar 3, 2008 03:23 PM
jd3772001
Sep 6, 2007 08:15 AM
theatreman
Nov 10, 2006 01:15 AM
