07 Cts DIC
Old Aug 26, 2016 | 12:28 AM
Mikeycts95's Avatar
Default 07 Cts DIC
I got a Cts and there is no DIC in it because the previous owners took it out for the aftermarket stereo. Any suggestions ?
Old Aug 26, 2016 | 12:39 PM
You could go to dealer with the VIN he should be able to tell what was in it originally. you will need to take Aftermarket one loose to see what installer did. If you are lucky jumper harness was installed and original wiring is not hacked up. so OEM radio would plug in and be programmed. If wiring is cut up you will need to undo what was done and correct any issued related to the A/M install.
Mikeycts95
Aug 26, 2016 12:23 AM
crescentbeach
Jul 20, 2007 08:32 PM
coupedeville
Jun 19, 2007 06:08 PM
WILLIEA
Nov 29, 2006 09:53 PM
WILLIEA
Nov 6, 2006 05:02 AM
