04-07 cts timing chain
Old Sep 5, 2016 | 09:50 AM
#Duramax01's Avatar
Default 04-07 cts timing chain
Hi all.....I was thinking about buying a 05 cts. I was going to buy one from a man that says it needs a timing chain as the engine is noisey...I have no problem doin the work myself. However I don't know much about the cts. I'm wondering if there is a reason why I shouldn't get involved with the project. After I change the timing chain will the engine noise be gone or is there a chance that there is permanent engine damage from not changing the chain before the engine noise started??...any info on this is appreciated
Old Sep 8, 2016 | 05:11 PM
It is an interference engine if chain jumps valve(s) will get bent. Bent valves should set ses light and misfire codes. If its just a worn chain replacing chain, guides and any other worn parts should make noise go away. Bent valves usually leads to engine replacement
brownwc70
Nov 30, 2019 02:11 PM
imageres
Aluminum Block V8s
Jul 12, 2011 09:29 AM
mattmondo
Sep 17, 2010 08:41 PM
Mar 5, 2010 10:39 PM
r3db0ss
Aluminum Block V8s
Mar 5, 2008 06:11 PM
