HT4100 Timing Chain Replacement
Old Mar 3, 2008 | 05:04 PM
r3db0ss's Avatar
Default HT4100 Timing Chain Replacement
Hi, how often do i need to change /replace the timing chain on my 4.1 deville?
I have 175000 miles on it. Do i need to worry about it?
How do i find out if i need to replace the timing chain?
Thanks
Old Mar 3, 2008 | 06:39 PM
Default RE: HT4100 Timing Chain Replacement
An GM Drive Train Engineer told me once: "the timing chain doesnt owe you anything after 100,000 miles"
Being that he was one of "the men" in the development of all three Allante engines, I do listen to his advice.
I'm running around 140,000+ on it and I pray at it - a lot. Engine still pushed that Allante to 110mph just three months ago and held up well.
A full time mechanic told me that an erratic idle where one can show erratic timing is a definite change the chain yesterday. In my cars, I can pull the D.I.C. and check the timing while traveling at any speed, so far, she is looking good.
Old Mar 5, 2008 | 09:27 AM
r3db0ss's Avatar
Thanks for the info, i appreciate it. So i guess i should then change it asap, running that high of a mileage.
Is it a big job, to change one of those for this engine?
Old Mar 5, 2008 | 04:41 PM
carnut's Avatar
A timing chain is a big job regardless of engine. The 4100 has some differences in thermostat housing ( depending on car its in) and bolts used to attach the water pump to the timing cover. Do you have a factory service manual? Are you doing this yourself? Do you rank yourself a better than average shade tree? Factory service manual is a MUST if you do this yourself.
Old Mar 5, 2008 | 06:11 PM
Big job? little bit. Year and model?
brownwc70
Nov 30, 2019 02:11 PM
stealtreasure
Mar 10, 2016 02:37 PM
imageres
Aluminum Block V8s
Jul 12, 2011 09:29 AM
mattmondo
Sep 17, 2010 08:41 PM
Mar 5, 2010 10:39 PM
