abs pump motor
Old Aug 14, 2009 | 08:00 AM
johnnyo's Avatar
Default abs pump motor
Help!!!???
I have a 91 allante, pump motor runs constant... have replaced the whole abs unit per mitchells pinpoint testing... no codes coming from abs, but red brake light on constant plus message center displays abs disabled/traction control disabled. If pump motor is bad will it run constant due to lack of power to charge ac***ulator??? is there a spec for pump output to test??? any help would be greatly appreciated...
Old Aug 14, 2009 | 09:12 AM
Originally Posted by johnnyo
Help!!!???
not good at all .. that is a $200 to $900 pump. dont let it run non-stop.
replaced whole ABS? when?
mitchells pinpoint testing ? explain ...
the details are unclear .. please clarify.
but you got a couple of potential issues ...
- the ABS relay that controls the pump - good luck, not avail except at salvage yards - good news is that usually when this fails, the pump will NOT run.
- the ac***ulator failing to keep a charge - $250 rem
- leak in high pressure hose - $75 rem
- pump seals are done, pump - $200 to $900
- low fluid
jross469
Cadillac Allante 1987 to 1992 Phase I & II
Sep 1, 2010 12:26 PM
99STSGUY
Aluminum Block V8s
Jul 7, 2010 06:52 PM
jono6406
Feb 13, 2008 12:13 PM
jono6406
Vehicular Projects
Jan 26, 2008 08:22 PM
tpcook
Dec 13, 2007 04:43 PM
