vibrating brakes - 2003 SLS with 55600 miles
Old Jan 21, 2009 | 12:59 PM
FriscoSLS's Avatar
Default vibrating brakes - 2003 SLS with 55600 miles
-whenever i'm driving at. Speeds. Greater than 30mph my brakes vibrate when I brake it is starting to worry me any suggestins would be aprexiated
mod edit
title
Old Jan 21, 2009 | 01:36 PM
Default RE: vibrating brakes
ORIGINAL: FriscoSLS
again, we are guessing since you dont provide model year.
I might guess that your rotors are shot?
Old Jan 21, 2009 | 09:35 PM
FriscoSLS's Avatar
Im sorry it is a 2003 SLS with 55600 Milesby shot what do you mean?
Old Jan 22, 2009 | 12:42 AM
if the brake pedal oscillates / vibrates when you hit the brakes, chances are the rotors are warped.
Old Jan 24, 2009 | 06:03 PM
derrickwi's Avatar
I have a 2000 DTS andhave the same problem. I have changed pads, rotors and wheel bearings. Dealer says all ball joints are good. Rims are OEM. When I break harder vibration goes away. Just cant get rid of it so I live with it now.
Could it becalipers? Unlikely?
Old Jan 24, 2009 | 09:19 PM
ORIGINAL: derrickwi
every pulsating brakes pedal I have ever seen is tracked to a out damaged, defective, worn, glazed, or warped drum or rotor. not the calipers.
if the brakes were overheated and you got BLUE metal on the brake surfaces, I consider that as time for new ones.
tommy
May 17, 2016 07:37 AM
FriscoSLS
Mar 23, 2012 02:19 PM
Neli
Dec 16, 2009 06:13 PM
FriscoSLS
Feb 23, 2009 06:33 PM
EldoradoMD
Jul 14, 2007 11:52 AM
