2003 Cadillac SLS turning off while driving
Well i was driving last night and i stoped at a red light and the car turns off i put the car on park turn the key and it turns back on now today on the way back from school it happends again but it hessitates to turn on now the battery is brandnew changed it 8 months ago and the volts show 14.0 so can anybody help me plese. 2003 Cadillac sls V8 48,000 miles
I took it to aamco they checked it out it was a crank sensor how much those that go for they said 200 plus parts they dont know which one it is they said it could be the a or b sensor
That price sounds about right although if you have a good reputable mechanic do the work you might get cut a deal on labor. DON'T have a Cadillac dealership do the repairs, you'll pay out the nose! Both A and B sensors were bad on mine. If only one is bad, it might not be a bad idea to have both of them replaced at once. Keep up on your repairs and your SLS should treat you right for many years. I've had mine almost two years and have only had to replace the crank sensors and battery. Also give it some WOT when you can, it works.
ORIGINAL: FriscoSLS
What does history mean when you run diognostics
history codes means it happened.
current codes means it is happening.
if your sensor has a glitch, it will show "current" while it is happening,
but when you power down and restart, it may well go to history.
that is why you were asked to post the code ...
actually it would still be a good thing to post it that way YOU will be
helping others identify the problem.
