Master brake cylinder
Old Sep 4, 2008 | 01:48 PM
rickster's Avatar
Default Master brake cylinder
I own a 1990.5 Cadillac Allante . the brake master cylinder is leaking on the floor.It seems only to leak when the brake peddle is depressed with the motor off. It is only a drip. Any ideas other than replacement?
Rick
Old Sep 5, 2008 | 04:08 PM
Big5DoubleZero's Avatar
Default RE: Master brake cylinder
Nope
Old Sep 5, 2008 | 04:15 PM
carnut's Avatar
Yes, tell uswhere on the master, its leaking. If its the fluid container, you can replace theO rings, if its a line, tighten it up. If its a hose, replace it.
Old Sep 5, 2008 | 04:32 PM
I didnt come up with a part number though for you in the aftermarket OEM so I am assuming that is probably dealer only.
Old Sep 5, 2008 | 04:37 PM
ORIGINAL: rickster
.......master cylinder is leaking on the floor...........
Rick
Are you talking the Garage floor? (possibly fixable)or thefloor on inside of the car? because my first reply is if its dripping on the inside of the car.
Ludde
May 12, 2015 02:05 AM
turbocat
Jun 13, 2011 05:02 PM
jross469
Cadillac Allante 1987 to 1992 Phase I & II
Sep 1, 2010 12:26 PM
9treseville
Dec 22, 2007 03:27 PM
zamboni46
Apr 4, 2007 10:09 AM
