Master brake cylinder
I own a 1990.5 Cadillac Allante . the brake master cylinder is leaking on the floor.It seems only to leak when the brake peddle is depressed with the motor off. It is only a drip. Any ideas other than replacement?
Rick |
RE: Master brake cylinder
Nope
Yes, tell uswhere on the master, its leaking. If its the fluid container, you can replace theO rings, if its a line, tighten it up. If its a hose, replace it.
I didnt come up with a part number though for you in the aftermarket OEM so I am assuming that is probably dealer only.
ORIGINAL: rickster .......master cylinder is leaking on the floor........... Rick |
