1992 deville 4.9 liter
Old Apr 30, 2010 | 06:37 PM
jamberi's Avatar
Default 1992 deville 4.9 liter
Hi,
I have problems when the tank registers 4 gallons or less while making turns. There is a loss of power until the car levels off. Could it be the fuel pump is going bad? Also, if you know, what brand is the best replacement pump? This is a fuel problem, not a brake problem as the category shows.
Jamberi
Old Apr 30, 2010 | 08:19 PM
The problem will evolves around sender assembly. GM revised the sender, it is a somewhat pricey fix.(No, it was never a recall) I dealt with condition as " I need to get gas SOON" never fixed it, I used the cutting out as a get gas or "Hope I brought my walking shoes"
Old May 1, 2010 | 07:43 PM
jamberi's Avatar
Default 1992 caddy deville
Is the fuel sending unit a part of the pump, or is it a separate item on the rail? My book says nothing about a fuel sending unit.
Jamberi
Old May 1, 2010 | 08:06 PM
It is the part the pump mounts to. You have to drop tank to access it. If you choose to replace it, replace pump and strainer...since you are there.
Old May 2, 2010 | 10:24 PM
jamberi's Avatar
Default Thank you slowroll
Heh:
Thanks a lot for the info. I bought a new pump and strainer. I will do the repair next weekend. Again, thanks.
Jamberi
Old May 9, 2010 | 02:10 PM
Adams' Apple's Avatar
My '93 D-Evil did the same thing, and would also cut out if on an incline, anytime it got down to around 4-3 gallons. New pump/strainer, and the hoses that connect it all fixed the issue on that one.
shredder1989
May 20, 2012 10:28 PM
1992blkseville
Oct 3, 2009 12:37 AM
wrtnova
Jul 23, 2007 02:37 PM
choust1
Aluminum Block V8s
May 7, 2007 06:22 PM
