Brake system
Old Jun 23, 2010 | 03:44 AM
farily's Avatar
Default Brake system
The modern automotive brake system has been refined for over 100 years and has become extremely dependable and efficient.
The typical brake system consists of disk brakes in front and either disk or drum brakes in the rear connected by a system of tubes and hoses that link the brake at each wheel to the master cylinder. Other systems that are connected with the brake system include the parking brakes, power brake booster and the anti-lock system.
When you step on the brake pedal, you are actually pushing against a plunger in the master cylinder, which forces hydraulic oil (brake fluid) through a series of tubes and hoses to the braking unit at each wheel. Since hydraulic fluid (or any fluid for that matter) cannot be compressed, pushing fluid through a pipe is just like pushing a steel bar through a pipe. Unlike a steel bar, however, fluid can be directed through many twists and turns on its way to its destination, arriving with the exact same motion and pressure that it started with. It is very important that the fluid is pure liquid and that there are no air bubbles in it. Air can compress, which causes a sponginess to the pedal and severely reduced braking efficiency. If air is suspected, then the system must be bled to remove the air. There are "bleeder screws" at each wheel cylinder and caliper for this purpose.
madmax123
Sep 2, 2013 02:08 PM
George Erneston
Mar 2, 2012 10:53 PM
Eldo69
Jul 11, 2010 12:49 PM
99STSGUY
Jan 21, 2009 08:29 AM
Jan 2, 2009 01:10 AM
