2000 Catera Tranny Sensor
Old Mar 24, 2010 | 11:40 AM
Brians's Avatar
Default 2000 Catera Tranny Sensor
Hi, my 2000 catera just shut down on me. Computer code says a sensor is detecting tranny is stuck in 4th gear. Any idea were I go from here?
Old Mar 24, 2010 | 10:14 PM
Adams' Apple's Avatar
Need more info.
What specific code(s) does it have?
When you say "Shut down", what specifically does that mean? The engine shuts down, or the trans just won't move the car?
Old Mar 25, 2010 | 06:48 AM
Brians's Avatar
Sorry, I don't remember the exact code but I will get it tonight. In the mean time, my son pulled up to a stop sign and it was as though someone shut the car off. Now it won't start. I believe a local auto shop told me the code meant a tranny sensor was detecting it was stuck in 4th gear therefore shut the car down. I will post the exact code tonight.
Old Mar 25, 2010 | 07:21 AM
There are NO trans related codes that would kill the engine, and keep it from re-starting. The only possible thing is if the lock-up clutch in the torque converter is "stuck on", for whatever reason, it would kill the engine when you pulled up to a stop, but it would NOT keep it from re-starting.
We'll have more to go on when you post the code(s) later.
Old Mar 25, 2010 | 06:26 PM
Brians's Avatar
The code is P1870
Old Mar 26, 2010 | 07:32 AM
1870 is a "Trans component slipping" code. It simply means the PCM has detected a slippage, or a mis-match of RPM to vehicle speed. 1870 is usually caused by a slipping, or otherwise malfunctioning lock-up clutch in the torque converter, but there could be other issues as well. This code will definitely NOT shut the engine down, or keep it from starting. Sounds like the are other Gremlins at work as far as the engine problem...
Old Mar 27, 2010 | 01:32 PM
Brians's Avatar
Well, originally I thought maybe he ran it out of gas. I have since put at least 5 gallons in the tank. Still it doesn't start. If in fact he did run it empty could there be something I need to reset or bleed??
Old Mar 27, 2010 | 08:09 PM
No, Check fuel pressure and condition of spark plugs.
Old Mar 29, 2010 | 02:24 PM
Brians's Avatar
Fuel pressure tester needle doesn't even move! Now what?
Old Mar 29, 2010 | 02:40 PM
Brians's Avatar
Fuel pump doesn't make any sound when I turn the key. I checked the fuse. It's good.
Cadillac-Catera
Jul 18, 2022 12:40 AM
kdg03
Other US Market Cadillacs
Sep 23, 2014 12:35 AM
caterable
Automatic Transmissions
Nov 23, 2011 12:18 PM
edgrmndz
Mar 17, 2011 10:35 PM
Oct 14, 2007 04:18 PM
