93 eldorado wont start
Old Nov 29, 2008 | 01:47 PM
briann's Avatar
Default 93 eldorado wont start
i have a 93 eldorado 4.6 northstar. engine will turn over,fire once and nothing else. the only code is p032.
Old Dec 4, 2008 | 11:32 PM
cummins777's Avatar
Default RE: 93 eldorado wont start
Make sure that the Map sensor is hooked up and If you have a scan tool handy make sure the BARO and the MAP sensor are reading the same with Key on engine off. If not its probably time for a new Map sensor. Also Make sure all the vac***e lines arent broken or disconnected espeasally the big ones like the brake booster, and the pcv.
94 cadillac sts Northstar
Old Dec 5, 2008 | 08:58 PM
Code may be caused by stalling.Can you better explain condition?
Jack West
Nov 12, 2012 11:07 AM
stevenmejia82
May 1, 2012 06:29 PM
birchnick10
Jun 27, 2008 09:32 PM
umoms
Mar 3, 2008 02:04 PM
beaujones
May 16, 2007 01:01 PM
