Adding an aux input 03 Deville
Old Sep 9, 2008 | 07:31 PM
eechapa's Avatar
Default Adding an aux input 03 Deville
I have an 03 Deville i want to install a wired fm modulator but i need help with removing the factory radio to get to the antenna wires. can anybody help with this matter? I tried wireless modulators but the sound was not good so i ordered the wired fm modulator but i am not sure how to remove the factory radio to get to the antenna wire. I would appreciate your help with this matter. Thanks Edgar
Old Sep 9, 2008 | 08:26 PM
atx deville's Avatar
Default RE: Adding an aux input 03 Deville
I have an 04 deville and I have a 'panel popper' but a flathead screwdriver should work. The plastic bezel around your radio and AC controls...pry from bottom right corner, then bottom middle, then bottom left and then you should be able to work kind of pry it off upwards. The radio has a clip on both sides that you can pry out.
Old Sep 9, 2008 | 09:16 PM
eechapa's Avatar
ok thanks i will try that tomorrow.
willfeom
Jan 17, 2011 05:43 PM
beddism-caddy
Mar 11, 2009 06:39 PM
PaulieWalnuts
Aug 1, 2006 12:44 PM
ronbo001
Dec 3, 2005 10:36 PM
kevinrea
Sep 20, 2005 03:03 PM
