US Emissions Have a question about getting your car to pass a state emissions test? Ask here.
The EGR Valve and its effects on engine performance, pinging, emissions, SMOG, fuel economy
Old 01-11-2009, 01:51 PM
1989 fleetwood's Avatar
Default The EGR Valve and its effects on engine performance, pinging, emissions, SMOG, fuel economy
my egr valve is stuck closed. I didnt think id need to fix it but a freind told me that it being stuck closed is the reason my oil gets dirty really quick. Is this true becuase my oil does seem extra dirty at 3k-5k miles. Is my oil loosing some ofits lubricating andcooling functions?
mod edit
title and content below:
Old 01-11-2009, 04:27 PM
Default RE: EGR Valve
You need to fix your EGR It will help with engine performance. It is unlikely to effect oil getting dirty rate. Engine operating temp, load, and how much dirty stuff is engine.(previous owners maintainance or lack of schedule.
Old 01-11-2009, 10:43 PM
i always thought that youd get more power from not having an egr valve because its just reserculating exhaust air into your intake. and the colder the air the more power right? isnt it just to make the air cleaner for emmisions?
Old 01-12-2009, 11:36 AM
carnut's Avatar
Older cars in the 70's sometimes ran better because the carb was lean and the EGR made the mixture even leaner. New cars with fuel injection benefit from EGR to control pinging and the computer depends on EGR to provide proper fuel delivery. A non functioning EGR has NOTHING to do with dirty oil?? it can cause pinging and lower fuel economy.
Old 01-12-2009, 05:09 PM
PLUS ...
it will hinder EMISSIONS and could cost you a SMOG TEST FAILURE!
Advice is to fix or replace ASAP.
Old 01-13-2009, 02:06 PM
Default RE: The EGR Valve and its effects on engine performance, pinging, emissions, SMOG, fuel economy
well shoot, i wasent looking forward to buying the 80 dollar part but yall convenced me. Its just two little bolts holding it on isnt it? Do i just need to disconnect the vacuum line then reconnect?
Old 01-13-2009, 02:37 PM
carnut's Avatar
Yes, but while its off clean out the EGR passage in the manifold.
strabo40
10-01-2019 12:25 AM
dipsetbitch
09-04-2009 09:11 PM
NAFTA
06-08-2008 12:05 AM
4point9
06-07-2008 06:21 PM
Roman
11-30-2006 12:24 AM
Quick Reply: The EGR Valve and its effects on engine performance, pinging, emissions, SMOG, fuel economy
