Sponsored by:
Sponsored by:
"Service Stabilization System" + ABS light + Traction Control Light + 2nd gear starts
Old 05-19-2009, 10:07 PM
andrew61987's Avatar
Default "Service Stabilization System" + ABS light + Traction Control Light + 2nd gear starts
98 DeVille. The problem is intermittent, it comes and goes and the car performs fine when it's not there. I scoured through the computer's menus while the problem was occurring and this is what I found:
TCS 1228 History
TCS 1242
TCS 1243 History
Does this mean the current problem is only 1242? What does this mean?
Old 05-19-2009, 11:17 PM
99STSGUY's Avatar
Hi, yes im not a professional or anything but i believe thats right. The other two are history meaning it probably happened before and it was fixed or etc.. but yes i believe that is current as of now.
Old 05-20-2009, 02:38 AM
TCS 1228 History
TCS 1242
TCS 1243 History
history is a past event
w/o history is a current event.
check/clean/di-electric all the connectors to the brake master cylinder
if you are having intermittent traction control issues that be one place to check.
Old 04-23-2010, 06:41 PM
dirtylow's Avatar
Great advice Stealth,
"check/clean/di-electric all the connectors".
Thanks
frankM
01-27-2017 06:39 PM
David L Quinn
Automatic Transmissions
06-14-2014 09:46 PM
bsstyle2011
03-22-2011 04:07 PM
simmy
03-07-2011 01:43 PM
99STSGUY
Aluminum Block V8s
07-07-2010 06:52 PM
Quick Reply: "Service Stabilization System" + ABS light + Traction Control Light + 2nd gear starts
