"Service Stabilization System" + ABS light + Traction Control Light + 2nd gear starts
98 DeVille. The problem is intermittent, it comes and goes and the car performs fine when it's not there. I scoured through the computer's menus while the problem was occurring and this is what I found:
TCS 1228 History TCS 1242 TCS 1243 History Does this mean the current problem is only 1242? What does this mean? |
Hi, yes im not a professional or anything but i believe thats right. The other two are history meaning it probably happened before and it was fixed or etc.. but yes i believe that is current as of now.
Originally Posted by andrew61987
(Post 31869)
TCS 1228 History TCS 1242 TCS 1243 History Does this mean the current problem is only 1242? What does this mean? w/o history is a current event. check/clean/di-electric all the connectors to the brake master cylinder if you are having intermittent traction control issues that be one place to check. |
Great advice Stealth,
"check/clean/di-electric all the connectors". Thanks |
