2000 Eldorado ETC oil pressure alert
Old 07-14-2016, 09:43 AM
lil ole lady's Avatar
Default Battery solved problem
Originally Posted by Dustysdad
My battery appears to be strong - not old. Was the battery the only thing you replaced to fix your problem with the false Low Oil Pressure alert?
Yes, the battery eliminated the problem. I still get a signal that headlights are advised, even on the sunniest day! Weird, but easy to ignore.
  #12
Old 07-14-2016, 11:17 AM
Dustysdad's Avatar
Default Thanks Lil Old Lady
Appreciate the response. I'm going to do a code check and look at the sending unit. May have a different problem from yours but, I'll clean my battery terminals anyway. Thanks.
  #13
Old 07-14-2016, 12:08 PM
lil ole lady photocell for automatic headlamps is under defroster grill of dash pad. If auto headlight are off and photocell is shaded, message will display. In states where stickers are applied to lower center of windshield it can happen more often.
  #14
Old 07-14-2016, 12:17 PM
Dustysdad use OBD to find out what codes are stored and in what modules. Since you love car you need to get FSM set so you can work on it. Checking grounds, battery cable condition are pretty much where you have to start. I suggest you start a new thread related to other issues.
  #15
Old 08-25-2016, 12:15 AM
I just wanna comment on lil ole ladys original post. She states that she has plenty of oil at 83%. That is the oil QUALITY before it needs changing...Not the oil QUANTITY! Huge difference and I wonder if she knows how to check the oil quantity?? just wondering.....
  #16
Old 08-25-2016, 12:07 PM
Default Checking oil
'Scuse my ignorance! Thanks for clarifying quality vs quantity. Yes, I check oil pretty frequently.
  #17
Old 08-25-2016, 11:03 PM
Didnt mean to bring you down but with a name like "lil ole lady" and saying about your oil % I just put it out there that maybe you didnt know that much about cars.....sorry.
  #18
Old 12-06-2016, 03:18 PM
Bob Elsken's Avatar
From everything I've been learning...I'd say check the battery.
reginapate
10-27-2012 10:54 PM
hl8a
Big Block V8s
09-08-2008 06:18 PM
jim
11-30-2007 12:10 AM
Refugeez
04-07-2007 01:17 PM
EldoLady
10-17-2006 04:01 PM
Quick Reply: 2000 Eldorado ETC oil pressure alert
