hard start in cold weather new to cadillac
Old 11-19-2008, 02:42 PM
sinatra cadillac's Avatar
Default hard start in cold weather new to cadillac
hello i have a 97 cadillac deville and it is getting harder to start in the cold mornings. it starts fine on warm days though. is there something that acts like a "choke" on the engine that is not functioning properly? if so what is it called? thanks
Old 12-04-2008, 08:41 PM
Default RE: hard start in cold weather new to cadillac
I have the same year DeVille and I am having the same problem. I am curious to see what the fix is to this.
Old 12-04-2008, 09:00 PM
Every car if different, and geographic area can play in to it...so a little more info maybe required. SES light on is important along with known codes.
Old 12-04-2008, 09:08 PM
musique's Avatar
do you use regular or premium fuel? how long has it been since the car had a tune up? (spark plugs, properly gapped)
how do you drive the car, do you baby it? do you ever open it up on the highway, or do a swift 0-60? when was the last time the fuel filter was changed? have you ever cleaned the throttle plate?
for a '97 I would replace the plastic intake manifold, it may have a buildup of gunk.it mightbe a good idea for a car of that year.
Old 12-13-2008, 12:54 AM
I noticed that my car sounds loud in the mornings. Not quite a knock, but noticebly louder. I was thinking of switching to a synthetic oil. What do you guys think?
Old 12-13-2008, 12:55 AM
Some cars recommend a thinner oil in cold weather, is that the case with the Northstar?
Old 12-13-2008, 07:00 AM
5w30 should ok year round in most areas of the US. Noise could be carbon build up on pistons, and a decarbon is needed.
Dana Dunagan
Automatic Transmissions
11-24-2014 09:43 PM
juniorr214
04-14-2014 08:25 AM
miaustin
04-28-2009 11:55 AM
RichRich
04-23-2009 07:29 AM
TonesDaOne
03-21-2007 04:20 AM
Quick Reply: hard start in cold weather new to cadillac
