air ride suspension freezes in cold weather
Old Jan 31, 2007 | 04:34 PM
miaustin's Avatar
Default air ride suspension freezes in cold weather
in minus 20 degree F weather, the air suspension on our 2002 Cadillac Deville appears to give out. extremely rough ride. the local dealership has been unable to diagnose the problem. any ideas/similar problems out there?
thanks in advance,
m
Old Jan 31, 2007 | 10:30 PM
Dave S Texas's Avatar
Default RE: air ride suspension freezes in cold weather
Wrong tires?Extreme cold weather tires, like snow tires, are made with a different compound that is/feels softerthan regular tires.....minus 20dg? Way too cold for these old bones!
Old Feb 24, 2007 | 03:37 AM
Katzmans Caddy's Avatar
It's -20 here tonight and the car just does not like it. My rear suspension in thumping too. When it gets warmer it will be ok I am sure.
Old Apr 28, 2009 | 11:39 AM
Strutmastr's Avatar
The thing that most people don't know about air suspension is that the airbags are not meant to be in temperatures below 40 degrees and about 90 degrees. This is most of the WORLD. You will start having problems only when you are in those temperatures but then it will cause permanent damage. I would recommend going to strutmasters.com and checking out the conversion kits. They are powder coated American made steel coil springs. They are guaranteed to last the life of your car and can withstand any weather. I posted the link below so you can take a look.
http://www.strutmasters.com/cadillac...parts-s/12.htm
I hope I was of some help
Good Luck!!!
Old Apr 28, 2009 | 11:55 AM
Strutmastr's Avatar
The thing that most people don't know about air suspension is that the airbags are not meant to be in temperatures below 40 degrees and about 90 degrees. This is most of the WORLD. It will start out as only having problems when you are in those temperatures but then it will cause permanent damage. I would recommend going to strutmasters.com and checking out the conversion kits. They are powder coated American made steel coil springs. They are guaranteed to last the life of your car and can withstand any weather. I posted the link below so you can take a look.
I hope I was of some help.
Good Luck!!!
Dana Dunagan
Automatic Transmissions
Nov 24, 2014 09:43 PM
Right2Bear
Mar 15, 2009 10:29 PM
Mar 7, 2009 01:31 AM
sinatra cadillac
Dec 13, 2008 07:00 AM
TonesDaOne
Mar 21, 2007 04:20 AM
