92 sedan deville... hard warm start
Old 09-22-2007, 09:09 PM
tonym2180's Avatar
Default 92 sedan deville... hard warm start
car starts right up when cold,but drive it 10 minutes shut it off and try to restartthe car ...it has a hard time turning over. any suggestion id appreciate it
tony
Old 09-22-2007, 09:35 PM
Katzmans Caddy's Avatar
Default RE: 92 sedan deville... hard warm start
Hard start when hot points to a few things. In particular a very dirty air filter or poor battery connections, especially the ground. If you check those two things and replace air filter as needed and clean up battery connections things shouldimprove.
Old 09-22-2007, 09:54 PM
tonym2180's Avatar
i just bought the car and it runs really good besides that issue,now i see that the cables are in good shape,it seems to have two wires on each side,the positive runs straight down to the starter and then a second wire goes toward the firewall,the negattive grounds right next to the battery and also has a second wire...what are these for??
Old 02-23-2008, 12:24 PM
1989 fleetwood's Avatar
theres a negative and a positive running to the starter right? or am i mistakin
Old 02-23-2008, 11:09 PM
with the motor running, pull the vacuum line going to the fuel pressure regulator, look, feel and sniff for fuel, chances are you have a bad FPR, symptoms, easy cold starts, hard hot starts
Old 02-24-2008, 04:41 PM
is the 92 deville fuel pressure regulator in the same spot as a 89 fleetwood? is so where can i find my regulator because i have the same problem.
Old 02-25-2008, 12:11 AM
is your 4.5 throttle body injection? or is it PFI?
jack
08-20-2010 03:22 PM
allenpinney
06-27-2008 07:36 PM
malibuandryan
10-16-2007 07:02 AM
bidness97
03-01-2006 02:52 PM
bidness97
11-23-2005 04:54 PM
Quick Reply: 92 sedan deville... hard warm start
