92 deVille vats/starting
Old 04-22-2010, 05:48 AM
mickey9463's Avatar
Question 92 deVille vats/starting
Started with BCM problem. THEN car no start/no sound. Changed BCM. Installed resistor key bypass and then jumped starter. Car started and ran (assume key bypass and fuel signal OK???). Tried to restart with key.... No go. HELP!!
Old 04-22-2010, 05:38 PM
92_Daddylac's Avatar
is there a security light or any codes you can post.
Old 04-22-2010, 05:58 PM
If there is no security light, it is not a obivous VATS problem. Car does have a starter enable relay which could be the cause. If you don't have a manual (FSM is best) you need one, to figure it out.
Old 04-22-2010, 09:51 PM
mickey9463's Avatar
Default 92 deVille vats/starting
security light stays on..... No codes show up
Old 04-22-2010, 09:56 PM
mickey9463's Avatar
security light is on but engine starts with starter solenoid jump what is FSM... Factory service manual??
Old 04-24-2010, 01:45 AM
I would check wiring of the bypass system and check relays. Use a FSM (factory service manual) like Slowroll stated and make sure everything is wired correctly. Also was the bcm replaced before or after the bypass was installed. I would imagine it may require the need of the keys restistor settings which all you would need to do is turn key to the on setting for about 15 min. But with the bypass installed it may not work. Just a possibility I'm throwing out there.
Old 04-26-2010, 02:48 PM
mickey9463's Avatar
Default Thanks to all
didn't work with bypass. WHERE IS RELAY ? BEHIND BCM? WHAT DOES IT LOOK LIKE?
Curtis Shannon
07-11-2013 11:03 AM
macarose
04-17-2010 07:35 PM
robotic_junky
05-19-2009 03:28 AM
Cadillac Allante FAQ
04-02-2007 02:30 AM
Quick Reply: 92 deVille vats/starting
