US Emissions Have a question about getting your car to pass a state emissions test? Ask here.
2006 Escalade ESV
Old Dec 2, 2013 | 05:25 PM
  #11
djlan99's Avatar
If you post it here we can ALL help you.
I worked for Cadillac and The 2006 Escalade was the worst and had the most issues since it was the first year for that platform (2007) released early in 2006.
Codes should get you headed in the right direction.
You are having evap issues
vent solenoid at gas tank sticking (hard to fill with gas) stuck open (po440) vacuum leak
purge solenoid at engine sticking (engine stalling) pulling gas into the engine. when the tank is full of gas the fuel vapor monitor shuts off as to not pull raw fuel into the engine or contaminate the evap canister.
There are a few issues here and the best thing is a Tech 2 so you can pull vacuum and seal the system to check its operation.
A good shop will be able to do this for you and not the one you took it to.
tonyb2580
Mar 2, 2011 11:54 AM
RovinC
Jun 8, 2008 02:09 PM
jbtindz1
May 1, 2008 08:05 AM
drdrh
Jan 10, 2007 11:09 AM
danksontl
Jun 11, 2005 09:52 PM
