TPMS help!!!
Old Nov 25, 2008 | 01:42 AM
08BLKESCALADE's Avatar
Default TPMS help!!!
So long story short I tow A LOT, and mostly around 6500 pounds. The truck came with 22" rims which just didn't work for the weight that I am towing. I went with a light truck tire which has deeper treads and a larger tire wall so it can hold the weight and get as much traction as possible. The tire HAS to be inflated to 60 psi when towing ( which is every day ) and the warning is being displayed in the info center in dash that the tired are way over inflated etc etc, and I even have OnStar calling now!!!! I went to the dealership and the said I have to basically deal with it, or inflate/deflate the tired when towing and not towing. There HAS to be a way around this!!! They also said that can't re-programm the truck to think that 60 is ok, but I'm thinking they can it's just a liability... Thedealership also said that the systemis connected with the ABS unitand all this other stuff... sigh....Please help! BTW- the truck is an 08 Escalade
Old Nov 25, 2008 | 01:09 PM
Default RE: TPMS help!!!
did you check the tow capacity before buying the truck? i think you'll find it is less than 6500 lbs. and that is why you may be having trouble.. i know, you didnt want to hear this stuff......
ok, just talked to one of my GM techs... they are able to reprogram the system and tell it that 60lbs is ok... however, there liability, and your warranty are issues at that point. possible if you give a waiver, they might accept, and do what you want
Old Nov 25, 2008 | 06:42 PM
The 08 is rated to tow up to 8500lbs. So, would they be able to just plug the Tech2 in and punch in the numbers I want and it's go time?
Old Nov 27, 2008 | 01:24 AM
santanerox3's Avatar
the tpms turns on only if u go over 7 psi or lower than 7 psi than the specs.
the specs should be on the driver door when u open it. and they should be able to reprogram the sensors. if the light is always on u might have a broken tpms
Old Dec 1, 2008 | 09:23 AM
how are you making out?
cmaitner
Mar 20, 2013 11:38 AM
green1
Jan 4, 2010 03:34 PM
08BLKESCALADE
Dec 1, 2008 01:27 AM
ilandjunke28730
May 8, 2008 07:14 PM
trakspeed
Oct 27, 2007 01:14 PM
