Suspension sponsored by Arnott Inc. Discuss anything suspension related within.
98 Deville rear shock noises and swaying back and forth
Old 04-18-2017, 07:34 PM
forgetaboudit's Avatar
Default 98 Deville rear shock noises and swaying back and forth
Hello,
I've attached a photo of one of the rear shocks. They both look like the picture. They bang and knock while going over bumps. The car also sways back and forth something fierce at speed. When I first turn the key on or start the car, I can hear the compressor kick on and run for about 5-10 seconds. Is it possible to spray soapy water over the air lines and shocks to see if bubbles form to indicate a leak? How do I narrow down what the issue is? I do know what a bad strut/shock sounds like, but I'm not sure if it could be something else in the caddy.
Attached Thumbnails 98 Deville rear shock noises and swaying back and forth-20170417_154507.jpg
Old 04-18-2017, 08:29 PM
The compressor coming on for 5-10 seconds indicates air shock function is okay. I would have someone who know about cars to ride with you and give you an opinion.
Old 04-20-2017, 05:54 PM
I am quite handy with car repairs and all. I know a bad strut sound, and this is it. But I wasnt sure it could be bad when there isnt a code thrown.
Old 04-21-2017, 11:56 AM
if actuators in struts rotate like they are supposed to they won't set codes.
Nwodeville76
09-22-2012 10:00 PM
handyboyski
Automatic Transmissions
11-03-2007 11:54 AM
dicknscott
05-11-2006 12:48 PM
dicknscott
05-11-2006 12:48 PM
Quick Reply: 98 Deville rear shock noises and swaying back and forth
