The water leak has been found!
Old Aug 12, 2007 | 12:30 AM
Nomar5's Avatar
Default The water leak has been found!
The leak in the trunk of many cadillacs has been found. I fixed the leak in my '98 Eldorado's trunk by caulking 2 areas. One of which was located at the upper driver side corner of the trunk. The other is in a similar area on the the passenger side. This particular caddy has one of those fake "convertible" vinyl tops installed; this may or may not be the cause of the leak. Anyway, you can fix it easily W/O TAKING THE TRUNK APART! By the way, you may want to use clear caulk; I plan on spraying mine gold though.
[IMG]local://upfiles/4240/C44C62F0F52B4DA597DAF4287AE77FA4.jpg[/IMG]
Old Aug 12, 2007 | 02:42 PM
76eldoragtop's Avatar
Default RE: The water leak has been found!
Thanks for posting this info.
V8stsblk
Apr 2, 2012 12:05 PM
edgrmndz
Feb 19, 2011 07:06 PM
Katzmans Caddy
Dec 23, 2007 11:07 PM
threnc
Jul 9, 2007 02:09 PM
