V coupe window issue after battery disconnect
Old Jan 25, 2012 | 05:25 PM
REDRACER's Avatar
Cool V coupe window issue after battery disconnect
This is an FYI for other CTS owners (mine is an '11 V Coupe) who disconnect the battery during winter storage periods to avoid battery drain. I noticed when I reconnected the battery that the window auto-up feature (auto-down continued to work) at the switch and the slight auto-down and auto-up mode when you open/close the door stopped working. Per the dealer, the computer "forgets" these operations when power is interrupted. To correct do the following: turn the ignition "on" (or start the car), fully lower the window, then fully raise the window and hold the switch in the "up" position for two seconds after the window reaches full up. Perform this procedure for each window and the computer will "re learn" these "auto" functions.
Old Jan 26, 2012 | 07:13 AM
Cadillac Customer Service's Avatar
@REDRACER, did performing this step on each door take care of your situation?
Michelle, Cadillac Customer Service
Old Jan 26, 2012 | 07:03 PM
REDRACER's Avatar
Thumbs up Retraining windows on V Coupe
Yes, the original auto features were restored (should have included that in the orig. post), it just takes a second to perform and was very easy to do. Thought it was good info for other folks that store their hotrods.
Jcramer85
Jul 7, 2014 06:59 AM
detroitchris
Dec 16, 2012 08:19 AM
mdyoussef
May 26, 2008 10:06 PM
moneymark25
Feb 21, 2008 10:44 PM
BAMBINO
Jun 20, 2007 12:34 PM
