Temp and light sensors
Old Oct 29, 2007 | 03:15 PM
planenuts's Avatar
Default Temp and light sensors
The temp and light sensors on my 2001 Seville (drivers side) have been pushed down into the dash. I was wondering how they are held in place and how to get them back in their correct position. I have tried lifting the back of the trim around the defrost opening to get at them, but I can't get enough space to get a finger on the sensors to see if they will just push back in place.
Old Oct 29, 2007 | 06:31 PM
Default RE: Temp and light sensors
Sensors twist 1/4 turn to lock in. You may have to remove upper dash panel to put them back in place.
Old Oct 31, 2007 | 08:52 AM
planenuts's Avatar
Thanks for the reply. How is the upper dash panel removed?
Old Oct 31, 2007 | 07:34 PM
Remove windshield pillar trim moldings. Remove 4 a/c vents , close off outlets so screws don't fall into dash. 4 screws, 1 in each outlet,. Lift front edge of dash and push toward windshield to release it then you should be able to remove it.You can also go by dealer and get copy of Do***ent ID# 857542
Bigdamo94
Nov 1, 2014 03:06 AM
68DevCon
Aug 22, 2010 03:50 PM
bigredcaddy
Jul 29, 2009 09:56 AM
ydrsbtr97
Jun 15, 2009 06:14 PM
NAFTA
Apr 14, 2008 10:00 PM
