Strange coolant leak
Old Jan 22, 2005 | 08:04 PM
mxblue23's Avatar
Default Strange coolant leak
I'm posting this for a friend of mine. He has a 92' sts with a coolant leak that we can not track down. It's leaving a puddle under the driveside front tire. I am an experienced mechanic but am stumped on this one. Checked all the hoses and they are good, radiator looks to be doing well, doesn't appear to be leaking out of the side tanks. Is this a common problem or freak of nature. It appears to only leak after it has sit for a bit after thoroughly warming up. Thanks for all the help guys
Old Feb 28, 2005 | 04:41 PM
tonythemongoose's Avatar
Default RE: Strange coolant leak
Dear MXblue 23,
Try looking at your over flow canister in some instances when a car is running at operating tempatures, or the car exceeds the specified manufactured tempature it can cause air to build up forcing the antifreeze to leak out of your over flow. You may want to check your thermostat to insure it opens and close properly, or flush your radiator to insure their is know rust or metal particles stopping the flow of antifreeze to your engine.
stixboy
Aug 30, 2009 11:14 PM
cady97dev
Aluminum Block V8s
Mar 20, 2009 08:10 AM
lferrebee
Aug 23, 2007 04:36 PM
strabo40
Dec 11, 2006 01:47 PM
mxblue23
Mar 13, 2006 04:28 PM
