Scored Cylinder Walls
Old Nov 10, 2012 | 04:51 PM
Gonekuku's Avatar
Default Scored Cylinder Walls
99 Northstar. 108K, drove it in the garage with suspected blown head gasket (1 & 2 were blown); however Cylinder 1 has vertical grooves and little dimples in the lower part of the piston and head, as if something sharp was tumbling inside for a while (a second). No valve damage. Grooves may be 10 thousands deep. Was this a piston ring fragment? Pull #1 piston? Is this block worth salvaging? If so, what steps should I take?
Old Nov 11, 2012 | 03:07 PM
Gonekuku's Avatar
With a feeler gauge I can at least tell the top piston ring is in tact. Unable to feel any gaps. Actually the grooves in the cylinder wall are nowhere near 10 thousandths, but easily detectable with a fingernail.
Old Nov 21, 2012 | 04:31 AM
ZacheryDon's Avatar
johnnyjaws
May 19, 2011 03:37 PM
wildphilhickup
Feb 25, 2010 10:04 AM
brodel34
Aug 4, 2007 10:18 PM
zamboni46
Apr 4, 2007 10:09 AM
JIMRUN
Mar 30, 2007 07:27 PM
