MIS FIRE CYLINDER
Old Mar 29, 2007 | 07:41 PM
JIMRUN's Avatar
Default MIS FIRE CYLINDER
Whats up guys? I havebeen alittle problem with my1997 Deville with 119,000 miles. When I accerate it' I get a little jerking and hesitation around 40mph. The check engine light came on once and this problem been going on for 3-4 months. If I take the time to let the vehicle warm up it drives alittle smoother. Any idea what my problem could be.
Old Mar 29, 2007 | 07:52 PM
JIMRUN's Avatar
Default RE: MIS FIRE CYLINDER
Also I failed to mention It the check engion light came on one time and I pulled the code and it sais miss fire cylinder one..
Old Mar 29, 2007 | 10:07 PM
Katzmans Caddy's Avatar
This one is my favourite because I know it well. I'm willing to bet that your wires and plugs are the original ones. With the kind of mileage you have on the clock it's time to change these. The code was probably P0301. It is easy to change these items yourself. On the back bank you need to move the coil packs/ignition module out of the way to change the back 4 plugs. Don't get cheap plugs and wires either go with GM - AC Delco replacement parts. While you are at it might as well change fuel and air filters too. This pretty much amounts to a tune up. You could also just change the plug on cylinder #1. If that works then you could get by without the others and wires. If not add a new wire to the new plug in #1 and see what happens. If you have the cash do them all.
Old Mar 30, 2007 | 03:06 PM
JIMRUN's Avatar
THANK YOU!
Old Mar 30, 2007 | 07:27 PM
Hey JIMRUN, just a bit of caution when doing the plugs, go easy to avoid mis-threading them. Aluminum chews up pretty easy so be sure they are in correctly when using the ratchet.
elucas
Oct 11, 2012 05:23 PM
Jun 26, 2007 04:25 PM
telliottcs2
May 15, 2007 12:48 AM
Mar 19, 2007 11:21 AM
matrix165
Jun 16, 2005 07:53 PM
