Remote Control Programming
Old Aug 5, 2007 | 07:59 AM
rafael nazario's Avatar
Default Remote Control Programming
I replace the front passenger side window and lock operator switch on my 04 ext escalade. Key less entry remotes are not working now. Anyone know how to program them?
Rafael
Puerto Rico
Old Aug 5, 2007 | 10:16 AM
Default RE: Remote Control Programming
tire sensors "reporting" the pressures on the DIC?
all doors and windows locked?
aer you sure the work you did realy locks the windows/doors?
the remotes are very picky about everything being locked.
but for programming, you may need the GM Tech scan tool:
plug in the scan tool, punch a couple of buttons, and it's done.
5 minutes.
some cars need that tool, dont know if yours is one of them.
Old Aug 5, 2007 | 12:13 PM
G.A.R.Y.'s Avatar
The simplist thing you can do is try rebooting. Disconnect the battery for 5 minutes and see what happens. As far as the work you did, I can't tell if you did any damage.
Old Aug 5, 2007 | 03:52 PM
Stealth, the reason why I replaced the part was because I had a "service tire monitor" message. And that problem was resolved with the replacement. The windows and locks work prefect from all the doors controls but the remotes are not doing anything. Any idea how to program without any especial tools?
Old Aug 5, 2007 | 04:09 PM
that only leaves "do a reboot" as Gary said.
other than that, maybe someone else will come along with better ideas?
Old Aug 5, 2007 | 05:39 PM
didn't work but thanks anyway
Old Aug 5, 2007 | 07:44 PM
FLCaddytech's Avatar
TSB address these issues.
Some customers may comment on any of the following conditions:[align=left]
The RKE key fob does not function.[/align][align=left]
The "Service Tire Pressure Monitoring System" message is displayed, if equipped.[/align][align=left]
The passenger door will not unlock from the passenger's or driver's door switches.[/align][align=left]
The passenger door window is inoperative.[/align]
You need to visit a dealer for a reprogram and possible further diagnosis.
Old Aug 23, 2007 | 04:32 PM
_X_CaddyTech's Avatar
The switch your replaced is the control module for all door locks. It is actually the FM reciever for the key fob and tire pressure monitors. if you replaced it you will need to visit a dealer to programm the key fobs to the vehicle and teach in the tire pressure.
jesusolorzano
Oct 16, 2008 04:36 PM
sgjf01
Sep 4, 2008 02:28 PM
SoFlaBuell
Nov 28, 2007 01:07 AM
nameloc_noid
Jun 9, 2007 11:47 PM
fleetwood chuck
Jan 2, 2007 02:09 PM
