power steering noise
Old Jan 5, 2008 | 07:49 PM
edj1993's Avatar
Default power steering noise
I am the second owner of an '02 SLS and have had for bout a year. The power steering pump is noisy and groans while turning the wheels. I replaced the pump myself and the new pump sounds the same.After installing the new pump, I steered througn lock to lock several times hoping that would get out any air. Are these pumps naturally noisy or is there something else I should check.. 59k miles. Thanks. mark
Old Jan 5, 2008 | 08:31 PM
Default RE: power steering noise
A little whine from the front of engine with hood open,is not uncommon. It should not be noticible with hood closed. Better describe noise when turning.
Old Jan 7, 2008 | 11:09 AM
edj1993's Avatar
Thanks.. The noise is a typical "hydraulic" type whine/groan that is often heard with pumps of this type, but is louder that I think it should be on a car like this. It is heard when thewheels are turnedwhether or not thecar is in motion. It can be heard under the hood naturally, butis very noticeable also in the passenger compartment. I am accustomed to just hearing more of a "hiss" from other power steering systems.. thanks
Old Jan 7, 2008 | 06:07 PM
Check to make sures P/S hoses/pipes are not contacting body. or sub frame.
Devil Dog
Aug 20, 2009 07:30 AM
mike1589
Sep 30, 2008 05:24 PM
psuperstar
Jun 14, 2008 02:03 AM
MickeyStarr
Aug 23, 2007 09:00 AM
