Power Steering
I have a 2000 DTS that has a leak on the high pressure power steering hose directly where the metal line interconnects with the rubber part, does anyone have any knowledge on replacing the power steering line. Thank you
NO fun,hose was redesigned you or not have it there is a bracket on rear head that needs to come off to change it.You want to get car as high as possible and need a 18mm crows foot socket to loosen fitting at gear,Route new hose same as old one.DO NOT USE ATF IN GM P/STEERING SYSTEMS IT WILL MAKE THEM LEAK.Hope it helps.
