'76 Eldorado light switch knob
Old Sep 26, 2007 | 02:30 PM
eldobob's Avatar
Default '76 Eldorado light switch ****
I am awaiting the delivery of a shop manual to help me with the various repairs on my '76 Edlorado convertible. I cannot figure out how to remove the plastic control **** off of the post that resides in the headlight switch on the dash so I can install a new switch. Is there a locking clip or special tool needed to accomplish this?
Thanks,
Old Oct 6, 2007 | 06:53 PM
Default RE: '76 Eldorado light switch ****
On some switches there a slot in **** and a pocket screw diver can depress retainer and **** will pull off switch,on ones where there is no slot its a little harder.You will need to remove trim so you can get your hand on switch, you will feel a button on switch it around a 1/4" in dia. pull **** out and button will not want to depress.Push **** in hold button down and **** should come out/off,be advised in either case if battery is connected the lights will be on,but on the 1st type you will be able to turn them off.Hope it helps
CadillacAttack.
Eldorado Seville
Dec 30, 2013 09:16 PM
DJWerkz
Mar 16, 2009 10:41 AM
PhantomR/T
Feb 26, 2008 01:25 PM
mooreman6
Manual Transmissions
Nov 16, 2007 06:07 PM
jashrs6
Jan 23, 2007 10:03 PM
