PCM PO507 code 2001 DTS
Old Jan 14, 2009 | 12:19 PM
BULA's Avatar
Default PCM PO507 code 2001 DTS
I haven't been able to find the real reason behind my idle problem. I just changed the camshaft sensor, cleaned throttle body and put in 44k additive. the car starts and drives good for about 20 minutes. but after a while the idle starts to jump to 1500-2000 rpm without me pressing on gas. Then when i put the car on park, the idle jumps to 25k rpm and the engine starts to heat up. when its rought to change the gear from park to drive. sometimes its too hard to stop the car because the idle keeps on raising. i got this code from the computer: PCM PO507. it says its for high idle but i don't know where to check. if i take it to the dealership, they'll rape me on the prices.
Anyone know where the leak or the problem could be at? any help would be appreciated.
Bula
Old Jan 17, 2009 | 10:23 AM
Default RE: PCM PO507 code 2001 DTS
Check for vacuum leak(s).
Old Jan 17, 2009 | 10:25 AM
ORIGINAL: BULA
Bula
we can assume it is car .. what we dont know is what model we got here.
Old Jan 25, 2009 | 07:56 PM
adixon3's Avatar
Check the throttle body gasket for leaks
Old Jan 25, 2009 | 09:51 PM
Check throttle intake for coke buildup !
clemece09
Dec 21, 2009 07:28 PM
travel777
Mar 31, 2006 08:12 PM
lilchris1500
Jan 12, 2006 02:46 PM
jimbo49
Apr 6, 2005 04:13 AM
