93 Cad pwr steering problem
Old Jan 25, 2009 | 01:03 PM
Hank Preusser's Avatar
Default 93 Cad pwr steering problem
93 60 Special develops air on one end of rack cylinder. Also oil in reservoir brown an smells overheated.
This fault causes instability in braking similar to warped rotors. Also no "hiss" when idleing and steering against stops. Pump worn out? Other. Help.
Old Jan 26, 2009 | 08:44 PM
Default RE: 93 Cad pwr steering problem
Power steering fluid being brown - it needs changed. The steering gear filling with air - need more info and how it effects brakes may require a little more.
Old Jan 26, 2009 | 10:11 PM
Slow roll --- Thanks for reply. Air in cylinder only ac***ulates in one end - corresonding to full left turn. It isn't affecting the brakes but it creates a soft steering when braking. It feels somewhat like the uneven braking caused by a warped rotor. To correct it I turn the wheel to the left stop with the car rolling slowly. I wondered if the air might be coming from a worn pump rotor.
Hank
Last edited by Hank Preusser; Feb 2, 2009 at 12:05 PM. Reason: Directing to "slow roll" / minor text edit.
norwal
Vintage & Classic Cadillacs
May 25, 2010 11:44 PM
wgoodlin
Nov 21, 2008 11:49 AM
jono6406
Aug 7, 2008 06:07 PM
DogTown Rancher
Apr 15, 2007 10:39 PM
mike1060
Apr 9, 2006 07:54 PM
