overheating problem
Old May 18, 2009 | 03:49 AM
dsmguy215's Avatar
Default overheating problem
hi I have a 2001 deville 88,000 miles car overheats in the city but on the highway it doesnt.I changed the waterpump, thermostat,radiator flush and changed the coolant.Radiator looks new.If i turn the car on leave it idle it takes about 10-15 minute to start overheating.No coolant smell in the tialpipe.Anybody can give me some hints?
Old May 18, 2009 | 07:56 AM
Originally Posted by dsmguy215
hi I have a 2001 deville 88,000 miles car overheats in the city but on the highway it doesnt. I changed the waterpump, thermostat,radiator flush and changed the coolant.Radiator looks new.If i turn the car on leave it idle it takes about 10-15 minute to start overheating.No coolant smell in the tailpipe. Anybody can give me some hints?
sounds like an air flow issue ...
rad fans working?
Old May 18, 2009 | 10:18 AM
did you use dex-cool? if car originally started with dex probobly should continue..... heard of the same and guy took off brand coolant out and dex-cool back in and all was fine.... just a sugestion
Old May 20, 2009 | 02:30 AM
dsmguy215's Avatar
fans work. question can a clogged catalytic converter made the car overheat?
Old May 20, 2009 | 02:39 AM
darn right it will.
but if it is clogged in the city, it is still clogged on the highway.
still sounds like the heat transfer from coolant to ambient air is not taking place.
are u sure the fans are working and working well?
on the highway, the ONLY difference is that the speed of the car pushes a lot of air through the radiator whereas in the city, the fans have to do it.
Old May 20, 2009 | 02:18 PM
Poland1's Avatar
Hi try to check if U have a right pressure in cooling system , does the coolant fluid go out when engine runs?
geoffrey560
Mar 7, 2011 06:00 PM
AlMunoz
Aluminum Block V8s
Dec 16, 2010 06:54 PM
98STS
Jun 28, 2010 02:43 PM
nphobb01
Nov 20, 2007 01:32 PM
Phil Swanson
May 19, 2007 01:13 PM
