overheating problem
hi I have a 2001 deville 88,000 miles car overheats in the city but on the highway it doesnt.I changed the waterpump, thermostat,radiator flush and changed the coolant.Radiator looks new.If i turn the car on leave it idle it takes about 10-15 minute to start overheating.No coolant smell in the tialpipe.Anybody can give me some hints?
Originally Posted by dsmguy215
(Post 31812)
hi I have a 2001 deville 88,000 miles car overheats in the city but on the highway it doesnt. I changed the waterpump, thermostat,radiator flush and changed the coolant.Radiator looks new.If i turn the car on leave it idle it takes about 10-15 minute to start overheating.No coolant smell in the tailpipe. Anybody can give me some hints?
rad fans working? . |
(Post 31812)
rickyd |
fans work. question can a clogged catalytic converter made the car overheat?
(Post 31874)
but if it is clogged in the city, it is still clogged on the highway. still sounds like the heat transfer from coolant to ambient air is not taking place. are u sure the fans are working and working well? on the highway, the ONLY difference is that the speed of the car pushes a lot of air through the radiator whereas in the city, the fans have to do it. . |
Hi try to check if U have a right pressure in cooling system , does the coolant fluid go out when engine runs?
