need help asap 98 deville fans not coming on
Old Feb 17, 2008 | 09:13 PM
  #11
32vnorthstar's Avatar
Default RE: need help asap 98 deville fans not coming on
car has not goten past 210 temp. i pulled out the connectors on the relays now i have a code . it has now went away but has came back not sure what code it is..
Old Feb 18, 2008 | 07:25 PM
  #12
If car has not gone over 210 why are certain there is a problem? A/C has to work for fans to come on.
Old Feb 18, 2008 | 08:16 PM
  #13
NAFTA's Avatar
yeah either that or hit a higher temp and then they turn on. i was concerned to when i got my first lac but then after asking around all my other buddies that drove cadillac turns out 196 - 224 is a normal running temp for the N*
Old Feb 18, 2008 | 09:31 PM
  #14
so what temp does the fan come on ? i just dont want too pop a head gasket . thanks
Old Feb 19, 2008 | 12:06 AM
  #15
i just read how to check codes , i will chech them tommarrow thanks
Old Feb 19, 2008 | 12:57 AM
  #16
NAFTA's Avatar
well the manual says 180 to 200 is the temperature, but i know it goes more than that functioning normally. I'm not sure but i think the fans go on somewhere around 216 on low and then go on heavy at around 226 somewhere, this is without the A/C on.
Old Feb 19, 2008 | 11:27 PM
  #17
ok , car has hit 220 now but still no fans .i pulled codes an there is 7 codes,
po401 egr flow insufficient,
po420 catalyst system low efficiency
po463 fuel level sencor circuit high
p1660 cooling fan control circuits
b1163 loss of serrial data - no lamp responce
b1327 vehicle system voltage below 9.0 volts
u1096 loss of communication with ipc
pcm ?
every thing seams to work good on the car but the fans an the drivers window .
so u guys tell me ? do i need to start a new tread ? thanks
thomasdean932
Mar 11, 2014 06:55 PM
fishv12
Feb 6, 2013 12:36 PM
michaeldkania
Jan 15, 2009 04:34 PM
mvintson
Sep 3, 2007 07:53 PM
JP500
Aug 22, 2007 02:23 PM
