motors
Old Sep 14, 2009 | 11:16 PM
jons95sls's Avatar
Question motors
i have a chance to buy a 96 sedan deville,i was wondering if this motor would fit in my 95 sls,not sure of the engine code on the 96 will post later,and the trans also.
thanks jon
Old Sep 15, 2009 | 07:02 PM
Engine should swap if they're both "Y". You will need to transfer cross over and probably intake. 96 is maf 95 uses map, are biggest differences. Basic long block is the same. Trans is another matter several changes during the early years. Trans codes may help, but I don't think it will be compatible between OBD I & II
Old Sep 16, 2009 | 07:48 AM
jons95sls's Avatar
so they made that many changes in the trans in 1 year? hmmm.
thanks for the reply
Old Sep 16, 2009 | 07:13 PM
Electric transmission, OBD II vs. I. The computer is very different and operates about 2 times the speed of OBD I. OBD II also requires more monitoring of things. Early 4T80-e did not have that many issues....Shift solenoids mainly.
Patrick
Nov 17, 2016 11:56 AM
SPreston2001
Sep 27, 2008 04:44 PM
Cadillac Allante FAQ
Feb 6, 2008 12:11 AM
Texan4Life
Jan 22, 2008 10:12 PM
