Loud squeaking 2000 dts!!
I'm experiencing a loud squeaking noise upon acceleration. I think the guy i bought the car from had large rims on the car w/o adjusting the suspension, (if that makes sense). Please help!!
Thanks for your quick reply...
Im hearing the noise in the front, as i hit the gas when pulling off and when i go over speed bumps, etc. i think its mostly coming from the right/passenger side. And the rear only squeaks when i go over these massive speed bumps around the city....
noise like this is hard to fix like this
but i will try
what u need to do is jack up front of vehicle put on jack stands
run the vehicle and see if the noise is there if so do this
remove left front wheel
remove the left front caliper tie it up out of the way
put the lug nuts back on with out the tire
run vehicle see if u hear the noise
let coast down dont step on brakes
if noise still there do the same on other side
we are basically elimating the brakes from the system
you could have a bearing noise
but that gets louder with speed almost sounds like a jet
we have had a bunch of front mounts go
and they ground out so u feel the car jump back like the enigine was leaving u behind
and it gives off a moan type noise (but all noise is different depends on break)
but i will try
469HP
Dec 19, 2007 11:50 PM
