Interior lights not working right.
Old Apr 17, 2008 | 07:35 AM
gadgeteer123's Avatar
Default Interior lights not working right.
I hit a deer quite a few monthes back and a couple of weeks after that the turn signal sorted out on the body and screwed up the interior lights only. the turn signals still work. The interior lights will only turn on one at a time, if i turn on two it gets dimmer if i turn on three it even gets more dim and so on, and when i turn the light switch on the dash only the floor lights work and it disables all the ceiling lights.
Old May 8, 2008 | 02:06 PM
Default RE: Interior lights not working right.
ORIGINAL: gadgeteer123
Any wiring damage?
Old May 9, 2008 | 12:00 AM
the blinker grounded out on the body but i fixed it within a few days of it happening.
Old May 9, 2008 | 12:11 AM
Default Interior lights not working right due to deer hit
the grounding and the heat ensued afterwards, may well have damaged/scorched the harness or even the module. trace the wires backwards and see what you find.
you may have to sue the deer for damages ...
sorry about the deer .. but maybe you can help with this thread?
https://www.cadillacforum.com/m_13051/tm.htm
Old May 9, 2008 | 07:23 AM
Default RE: Interior lights not working right due to deer hit
How am i supposed to trace the wire when the wire goes throughout the whole car.
Old May 9, 2008 | 10:59 AM
carnut's Avatar
You have at least a blown fuse, so see if replacement will correct the issue. If it blows again quickly you will have to visually inspect all items powered by that fuse.
Old May 10, 2008 | 02:08 AM
jerrymac's Avatar
'Dim" lights on any vehicle usually indicates a poor 'ground' in that particular circuit.
Old May 10, 2008 | 10:21 AM
there not dim unless i start turning more than one on.
fjs1966
Sep 18, 2012 08:06 AM
leemb
Dec 13, 2010 08:02 PM
ziggy
Feb 21, 2009 09:40 PM
cstyles
Oct 19, 2008 08:46 AM
33coup
May 16, 2008 02:01 AM
