2001 Catera Troubleshooting NEEDED!
Old Apr 14, 2008 | 11:17 AM
cwalcott's Avatar
Default 2001 Catera Troubleshooting NEEDED!
The TC and ABS indicator lights come on periodically which then trigger the CHECK ENGINE light followed by the speedometer & odometer to stop working. I have had someone work on it but after reading the codes the computer kicks out and checking the sources, theysay nothing appears to be wrong with the TC or ABS systems. Typically after letting the car sit for the night, when I get in and start the car, the TC and ABS lights are off but after about 15 minutes of driving they come back on. Has anyone had this problem before? Is it a fuse issue? I don't want to waste anymore money having someone fail to diagnose. Any suggestions for solving this problem would be helpful.
Old Apr 14, 2008 | 09:27 PM
Default RE: 2001 Catera Troubleshooting NEEDED!
Check ground near battery tray, what codes are stored also?
Old May 8, 2008 | 02:14 PM
ORIGINAL: cwalcott
did you ever get the codes?
Old May 12, 2008 | 06:40 PM
cwalcott's Avatar
Thanks for your patience. I had to track down someone to pull the codes for me. Here they are:
- P0500 (Vehicle Speed Sensor A)
- P1700 (Manufacturer Controlled Transmission)
- U2108 (Secondary ABS Code ???)
Let me know what you think.
Thanks again,
Chris
Old May 12, 2008 | 06:41 PM
cwalcott's Avatar
Thanks again,
Chris
Jeff R
May 18, 2013 09:38 PM
justtalkin
Aug 11, 2010 09:39 PM
djyungstylez
Feb 28, 2009 03:47 PM
cwalcott
May 15, 2008 08:23 AM
FredMaxwell
Mar 9, 2006 05:23 AM
