Hum in steering wheel
Old Apr 18, 2008 | 02:11 AM
  #11
jerrymac's Avatar
Default RE: Hum in steering wheel
You stated that the Hummm occurs on "sweeping" left hand turns. Does it do it while sitting still and turning to the left? If not, then it might not be a problem with the hydraulic system. Have you checked for a bad wheel bearing ? There is generally a lot more pressure exerted on a wheel bearing when making a turn than in traveling in a straight line. And , usually, the bearings opposite the direction of the turn will be the culprit , just like the nasty clicking noise of a bad CV joint on a front wheel drive car, when it clicks turning left, it is usually a bad joint on the right causing it. I am no expert in car repairs, since I have worked at a Mack truck dealership for many years, but, cars are just little trucks, lol..
Old Apr 18, 2008 | 09:04 AM
  #12
ORIGINAL: mechanical man
I don't think it is the ps pump as it only happens turning to the left.
Different bushings and seals to each side?
Old Apr 19, 2008 | 01:01 AM
  #13
brougham1's Avatar
I think you Caddy is humming because it's just happy to be alive.
Old Apr 19, 2008 | 08:14 AM
  #14
good point .. is it the Cadillac song?
Old Apr 20, 2008 | 01:58 PM
  #15
Noise in one direction and not other : steering gear likely cause. also check for grounded P/S hose.
1mpalaSS
Dec 11, 2008 07:03 PM
jrlancaster
Aug 19, 2007 06:20 PM
StealthSTS
Jul 25, 2007 08:56 AM
wrtnova
Jul 23, 2007 02:37 PM
Papadopoulos
Nov 2, 2005 07:21 PM
