rear end ratio
Old Apr 19, 2008 | 11:47 PM
enjoytheride's Avatar
Default rear end ratio
Howdy, I have gotten great info off the list, good job. Here is my question. I have a 1984 fleetwood, with the 4100 engine and over drive transmission. I recieved the car with 2.73 gears in the rear end. I am looking to replace them with the stock ratio of 3.42. I have located a 1988 brougham in a locate wrecking yard, the vin # is 1G6DW51Y1J9729688. Is there someone that can tell me what ratio is in this car by the vin #? Thanks in advance. Its all good, Jim.
Old Apr 20, 2008 | 01:52 PM
Default RE: rear end ratio
Check G codes on SPID label on trunk lid or numbers/letters stamp into axle tube(s). and post. If you pull cover #s stamped on ring gear will tell ratio also.
Old Apr 20, 2008 | 08:38 PM
I will check thoses. Thanks Jim
memez
Automatic Transmissions
63
Sep 27, 2011 11:24 AM
mysterygirl305
Mar 26, 2009 07:58 AM
btan
Aluminum Block V8s
Sep 25, 2008 12:38 PM
enjoytheride
Jan 12, 2008 10:45 PM
SLBeck
Nov 14, 2007 10:21 AM
